Hello!
I got my RUTM10 replaced with an RMA, but after restoring the backup of the old device everything is running, but the Guest Wifi devices cannot get an IP from the DHCP Server of the RUT.
I Created the Guest wifi using this Guide.
and it did functon before.
I aleready have an quite extensive config for the device so it would be not ideal to reconfigure everything from scratch (IPSec VPN with multiple networks, WAN,Logging, Mailsettings etc.)
in System Maintenance Events Log there is nothing DHCP related and my guest wifi:
|3022|2024-12-23 15:03:55|WiFi|Connections|Notice|BR_Gruen_Guest: WiFi client disconnected: my:wi:fi:ma:c|
|3021|2024-12-23 15:03:37|WiFi|Connections|Notice|BR_Gruen_Guest: WiFi client connected: my:wi:fi:ma:c|
|3017|2|
System Log is empty
My Device:
RUTM10
Firmware version
RUTM_R_00.07.11.4
Firmware build date
2024-12-17 13:06:40
Kernel version
5.10.226
Thank you for your input!
