Gsmctl via JSON-RPC on RUT2xx
Hi Folks,
I came around some issues playing with “gsmctl” via “json-rpc” on RUT240 (FW 7.6.19) and RUT241 (FW 7.19.3):
Logging in with curl and getting a token works fine.
Checking sms-memory should be done via:
…{ “command”:“gsmctl”, “params”: [“-S -t”]}…
but only works when leaving out the space and - after -S:
…{ “command”:“gsmctl”, “params”: [“-St”]}…
Trying to send an SMS to xxxxxxxxxxxx should work via:
…“params”: [“-S -s \“xxxxxxxxxxxx Test-SMS\””] …
but it doesn’t. Also not according to the workaround above with:
…“params”: [“-Ss \“xxxxxxxxxxxx Test-SMS\””] …
What am I doing wrong?
Best regards and thanks in advance!
If you’re passing multiple parameters (e.g.: -S, -t, etc.) - I believe the following needs to be used:
  "command": "gsmctl",
  "params": ["-S", "-t"]
Essentially, we’re treating -S and -t separately; therefore, we put them under separate quotes, divided by the comma.
Sames goes with the SMS, -S and -s together are treated as a single argument. For example, the gsmctl command would look like so:
gsmctl -S -s <number> <message>
So your JSON RPC would look like so:
  "params": [
    "-S",
    "-s",
    "<phone_number>",
    "Test-SMS"
Let me know if this helps,
Thanks Matas !
