Goodday everyone,
We are just testing with 3 RUT906 modems to send and receive SMS messages.
After trying different options, we are now focusing on using the cli based gsmctl.
After some initial fiddling with syntax en options, sending an sms is now a breeze.
The issue we have now is that reading the incoming messages doesn’t work.
It seems there are stored messages indeed, but the gsmctl binary runs into an error.
The commands I used and resulted in [almost] the same error are these:
gsmctl -D --sms --list all
GSMCTL modem[0]: Debug mode enabled
GSMCTL Modem id: 0
GSMCTL modem[0]: Calling List SMS
GSMCTL modem[0] SMS: Calling read SMS
[gsmctl_read_sms:74] error: ERROR: Unknown error (errno:1) ‘AT+CMGL=4\r’ => ‘\r’
gsmctl -D –sms –read 1
GSMCTL Modem id: 0
GSMCTL modem[0]: Checking SMS index
GSMCTL modem[0]: Calling Read SMS
[gsmctl_read_sms:74] error: ERROR: Fatal exception occurred (errno:4) ‘AT+CMGL=4\r’ => ‘\r’
When looking at the sms logs in /tmp, it seems that the modem does respond with a set of SMS messages:
gsm_1-1.4_202509101744.log:[2025-09-10 17:44:12] Sent: AT+CMGL=4\r
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 1,3,18\r\n07911326040000F011000B911346534838F60000FF04B35A0E07\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 2,3,59\r\n07911326040000F011000B911326442622F70000FF33C8344BA138A6DD67903AAD06B9DF67D0BD2C5F97DDA0B719E44E97E93F85E22C7F97E9EAF29CA550B85C2E970B\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 3,3,20\r\n07911326040000F011000B911316217210F00000FF0673F39C6C9E03\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 4,3,38\r\n07911326040000F011000B911316217210F00000FF1BD4F29C2E2ECBD363341D644F8741D22A3507B38182D06408\r\n\r\n+CMGL: 5,3,38\r\n07911326040000F011000B911316217210F00000FF1BD4F29C2E2ECBD363341D644F8741D22A3507B38182D06408\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 6,3,51\r\n07911326040000F011000B911356116755F90000FF2AD4F29C2E2ECBD363341D644F8741D22A3507B38182D064087496BFCB747579CE0249D3E335\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 7,0,28\r\n07911326040040F5240b911356116755f90000527090014413800ae872990d3abfcbe410\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 8,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n\r\n+CMGL: 9,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 10,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n\r\n+CMGL: 11,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 12,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n\r\n+CMGL: 13,3,43\r\n07911326040000F011000B911316217210F00000FF21C4341D949E83CA6537885E9ED3C565797A8CA683EC6137481B168BD378\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 14,3,18\r\n07911326040000F011000B911316217210F00000FF04F4F29C0E\r\n\r\n+CMGL: 15,3,27\r\n07911326040000F011000B911316217210F00000FF0EF7B27C5D7683DAEF321DA42E03\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 16,3,44\r\n07911326040000F011000B911346019149F80000FF22E730489D5683CA65F71C742FCBD765370B7496BFCB6A7A79CE02319FCC20\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 17,3,52\r\n07911326040000F011000B911326442622F70000FF2BD93708FD2E83D8E1301D442EBBD7207519640FBBC3F6B79B0CA2A3EBE939885E06E9D36AF70F\r\n\r\n+CMGL: 18,3,61\r\n07911326040000F011000B911346766402F80000FF35CAB41AC47EBFE174D0FBBD06B5C36139085D2EB341E432881C3E83DAE1B01C542EBB41E27299AE2E83E46F37D9E502\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 19,0,23\r\n07911326040040F5040b911346534838f60000527001515051800433192d07\r\n\r\n+CMGL: 20,3,18\r\n07911326040000F011000B911316217210F00000FF04B35A0E07\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 21,3,18\r\n07911326040000F011000B911316217210F00000FF04B35A0E07\r\n\r\n+CMGL: 22,3,18\r\n07911326040000F011000B911346534838F60000FF04B35A0E07\r\n
gsm_1-1.4_202509101744.log-[2025-09-10 17:44:12] Received: \r\n+CMGL: 23,3,18\r\n07911326040000F011000B911316217210F00000FF04B35A0E07\r\n\r\nOK\r\n
This last entry indicates a number 23.
That corresponds perfectly with the number in the modem webUI stating that the amount of messages stored and available space is both 23.
So, I do have several questions:
*can I manually reset the SMS storage via the webUI ?
why does gsmctl ends with an error when I try to list or view SMS messages ?
Is the 23 indeed the maximum number of SMS messages the modem can hold ?
Or is that expandable?
I hope someone can help us with this; they seem to be very mice machines, but this is of course an essential part of their usage, so if we don’t get this to work*….
Ydo Ehlers
