Grpcurl stralink location
I am trying to retrieve the GPS position of a Starlink antenna in a file using this type of command.
I am looking for an alternative to JQ to retrieve the response in a file. Could you help me?
Thank you for your help.
grpcurl -plaintext -d {\“get_location\”:{}} 192.168.100.1:9200 SpaceX.API.Device.Device/Handle | jq -r . > “/usr/local/response_$(date +‘%Y%m%d_%H%M%S’).json”
Response gprc:
“status”: {},
“apiVersion”: “40”,
“getLocation”: {
“lla”: {
“lat”: 48.38045822626718,
“lon”: -4.486677788247141,
“alt”: 49.86233211577027
“source”: “GNC_FUSED”
Could you please specify which device model you are using with your Starlink antenna?
we use a Statlink Mini.
Do you have a solution for using the Starlink position instead of the RutX12 GPS antenna?
Antoine
We can only assist with questions related to Teltonika devices.
Is pretty print needed? If no then you can directly output grpcurl to file
grpcurl -plaintext -d {\"get_location\":{}} 192.168.100.1:9200 SpaceX.API.Device.Device/Handle > "/usr/local/response_$(date +'%Y%m%d_%H%M%S').json"
If you want to prepossess json (no petty print tho) you can use bult-in jsonfilter command
