Grounding plane for combo sisi mobile/gnss/wifi roof mounted sma antenna | pr1kcs28
I am looking to get information on ground plane requirements for prk1kcs28.
Is a ground plane required for this antenna? If there is not, what are the size and material requirements? If not, is there a rule of thumb or recommendation for ground plane size for the best performance?
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 19578.
