Glitchy SIM-card once ever hour?
Once every hour my sim-card glitches out.
And then comes back automatically after one minute of downtime (see log below)
Why is this?
98 2024-10-04 11:19:29 CONFIG User “admin” changed dhcp configuration
97 2024-10-04 11:13:03 DHCP Leased 100.85.147.106 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
96 2024-10-04 11:12:58 Network Operator Connected to Telia Telia operator (internal modem)
95 2024-10-04 11:12:58 Network Type Joined 5G-NSA network (internal modem)
94 2024-10-04 11:12:58 Mobile Data Mobile data connected (internal modem)
93 2024-10-04 11:12:58 Switch Events Port speed for port LAN1 changed to 1000 baseT
92 2024-10-04 11:12:58 Switch Events Port link state of port LAN1 changed to UP
91 2024-10-04 11:12:57 Switch Events Port link state of port LAN1 changed to DOWN
90 2024-10-04 11:12:31 Web UI Password auth succeeded for admin on HTTP from 192.168.2.100
89 2024-10-04 11:11:03 Mobile Data Mobile data disconnected (internal modem)
88 2024-10-04 11:10:58 DHCP Leased 192.168.2.100 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
87 2024-10-04 11:10:55 SIM status SIM state changed to not inserted (internal modem)
86 2024-10-04 11:10:51 Switch Events Port speed for port LAN1 changed to 1000 baseT
85 2024-10-04 11:10:51 Switch Events Port link state of port LAN1 changed to UP
84 2024-10-04 11:10:49 Switch Events Port link state of port LAN1 changed to DOWN
83 2024-10-04 11:10:48 Mobile Data Mobile data disconnected (internal modem)
82 2024-10-04 11:10:47 SIM status SIM state changed to not inserted (internal modem)
81 2024-10-04 09:38:08 Web UI Password auth succeeded for admin on HTTP from 10.13.146.145
80 2024-10-04 09:06:24 DHCP Leased 10.13.146.145 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
79 2024-10-04 09:06:20 Switch Events Port speed for port LAN1 changed to 1000 baseT
78 2024-10-04 09:06:20 Switch Events Port link state of port LAN1 changed to UP
77 2024-10-04 09:06:19 Network Operator Connected to Telia Telia operator (internal modem)
76 2024-10-04 09:06:19 Network Type Joined 5G-NSA network (internal modem)
75 2024-10-04 09:06:19 Mobile Data Mobile data connected (internal modem)
74 2024-10-04 09:06:18 Switch Events Port link state of port LAN1 changed to DOWN
73 2024-10-04 09:05:22 Mobile Data Mobile data disconnected (internal modem)
72 2024-10-04 09:05:18 DHCP Leased 192.168.2.100 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
71 2024-10-04 09:05:15 SIM status SIM state changed to not inserted (internal modem)
70 2024-10-04 09:05:11 Switch Events Port speed for port LAN1 changed to 1000 baseT
69 2024-10-04 09:05:11 Switch Events Port link state of port LAN1 changed to UP
68 2024-10-04 09:05:08 Switch Events Port link state of port LAN1 changed to DOWN
67 2024-10-04 09:05:08 Mobile Data Mobile data disconnected (internal modem)
66 2024-10-04 09:05:07 SIM status SIM state changed to not inserted (internal modem)
65 2024-10-04 08:26:48 Web UI Password auth succeeded for admin on HTTP from 10.5.193.255
64 2024-10-04 08:26:36 DHCP Leased 10.5.193.255 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
63 2024-10-04 08:26:31 Switch Events Port speed for port LAN1 changed to 1000 baseT
62 2024-10-04 08:26:31 Switch Events Port link state of port LAN1 changed to UP
61 2024-10-04 08:26:31 Network Operator Connected to Telia Telia operator (internal modem)
60 2024-10-04 08:26:31 Network Type Joined 5G-NSA network (internal modem)
59 2024-10-04 08:26:31 Mobile Data Mobile data connected (internal modem)
58 2024-10-04 08:26:30 Switch Events Port link state of port LAN1 changed to DOWN
57 2024-10-04 08:24:26 Mobile Data Mobile data disconnected (internal modem)
56 2024-10-04 08:24:22 DHCP Leased 192.168.2.100 IP address for client 74:83:c2:fb:a2:7e - ubnt in LAN
55 2024-10-04 08:24:19 SIM status SIM state changed to not inserted (internal modem)
54 2024-10-04 08:24:14 Switch Events Port speed for port LAN1 changed to 1000 baseT
53 2024-10-04 08:24:14 Switch Events Port link state of port LAN1 changed to UP
52 2024-10-04 08:24:13 Switch Events Port link state of port LAN1 changed to DOWN
51 2024-10-04 08:24:12 Mobile Data Mobile data disconnected (internal modem)
50 2024-10-04 08:24:11 SIM status SIM state changed to not inserted (internal modem)
I use it on brigde mode, turned off DHCP (as you can see) but I dont think that the problem.
Could it be fysical? That the SIM-card needs support somehow? (i did some manual configuration of the sim-card adapters when installing the SIM-card (or it wouldnt fit)
Try IPv4 only and Auto APN
Good day,
Thank you for your query.
I am picking up on the network event log you have shared in line with SIM status, that the SIM state reported by the internal modem a change of SIM card not inserted.
e.g. line 55 “2024-10-04 08:24:19 SIM status SIM state changed to not inserted (internal modem)”
This can signify that the issue is related to the SIM card perhaps losing contact with the SIM pad, this can be caused by multiple factors, it can be that the router is operating in a high humidity or high vibration environment. We recommend the usage of a thin coat of dielectric grease on the SIM card contact to keep it in place in any of these factors.
In addition to this, i would also recommend removing the SIM card and cleaning the contacts, reinserting it, and checking if that helps.
Thank you
Turns out, I am the problem: inserted the SIM-card sloppy.
Solved by some extra tape :innocent::blush:
