Giving hotspot connection higher priority than eSIM possible?
If i connect my RUT241eSIM to a public hotspot bases on this artcile https://wiki.teltonika-networks.com/view/Connecting_to_a_Hotspot_WiFi_for_Internet_Connectivity
and i simultaneously are connected throug an eSIM profile, traffic seems to flow through the eSIM connection instead of the hotspot connecting i created. Can i give the hotspot connection a higher priority so the RUT241 tries the hotspot connection first and the eSIM connection second?
Yes, if you would like to use the hotspot (wireless WAN) as the primary internet source over the mobile (eSIM) connection, you can simply configure that on WebUI by navigating to Network → WAN page and dragging the hotspot interface (by default named wifi1, unless renamed) above the mobile (eSIM) interface. Once reordered, click Save & Apply
ezgif-7af717b108f722
Let me know if you have any further questions.
That simple :-), thank you very much.
