I have activated the RSTP- protocol on all 4 TSW212 switches (WebGui: Network → Spanning Tree → General → Mode: RSTP). Allong with the TSW212 switches, I also attach a embedded device which shall support RSTP as well. This embedded device I’m going to test. Accroding to the Wireshark traces the switches react as they should.
For testing purposes, I need to know which bridge get’s root-bridge and which information is the root-bridge sharing (I do not have access to the embedded device but must known the these information’s when the embedded device get’s root-bridge)
Therefore, I was using the follow cmd on a TSW212 switch:
brctl showstp br0
And it seem every bridge detect itself as root, even the wireshark trace proof the switch send’s the correct BPDU’s.
TSW212 with MC 20:97:27:6e:b8:b1 (expected as Root - Priority 4096):
BusyBox v1.36.0 (2025-07-08 05:05:13 UTC) built-in shell (ash)
_____ ______ _____ ____
|_ _/ ___\ \ / / _ \/ ___|
| | \___ \\ \ /\ / / | | \___ \
| | ___) |\ V V /| |_| |___) |
|_| |____/ \_/\_/ \___/|____/
Teltonika TSW2 series 2025
Device: TSW212
Kernel: 5.10.236
Firmware: TSW2_R_00.01.06.3
Build: beb6372c
Build date: 2025-07-14 11:55:46
admin@TSW212:/$ brctl showstp br0
br0
bridge id 7fff.2097276eb8b1
designated root 7fff.2097276eb8b1
root port 0 path cost 0
max age 10.00 bridge max age 10.00
hello time 1.00 bridge hello time 1.00
forward delay 8.00 bridge forward delay 8.00
ageing time 300.00
hello timer 0.00 tcn timer 0.00
topology change timer 0.00 gc timer 35.93
flags
port6 (6)
port id 8006 state forwarding
designated root 7fff.2097276eb8b1 path cost 19
designated bridge 7fff.2097276eb8b1 message age timer 0.00
designated port 8006 forward delay timer 0.00
designated cost 0 hold timer 0.00
flags
TSW212 with MC 20:97:27:68:95:63 (Priority 57344):
Device: TSW212
Kernel: 5.10.236
Build: beb6372c
br0
bridge id 7fff.209727689563
designated root 7fff.209727689563
ageing time 300.00
topology change timer 0.00 gc timer 80.66
flags
port4 (4)
port id 8004 state forwarding
designated root 7fff.209727689563 path cost 19
designated bridge 7fff.209727689563 message age timer 0.00
designated port 8004 forward delay timer 0.00
flags
Wireshark trace:
Does anyone have experience with RSTP in connection with TSW212 switches?
