Vemund
1
The router reports that the flash storage is full. Router is unreliable and a lot of lagging, failure to connect, ect.
Any tips on what i can delete?
What is the -FILTER file? Takes up most of the space
root@RUTX50:~# du -sh /overlay/upper/root/*
92.9M /overlay/upper/root/-FILTER
4.0K /overlay/upper/root/routing_table_backup.txt
4.0K /overlay/upper/root/testfile.txt
It’s difficult to understand what’s stored there without additional context.
If there’s no sensitive information, could you describe or provide part of what’s stored in
/overlay/upper/root/-FILTER ?
Also, could you run the command:
df -h
And take a screenshot? This would help in finding what’s taking up so much space. The output should look like this:
![2024-04-11-12-20-37-192.168.12.1](https://community.teltonika.lt/uploads/default/original/2X/c/caf90f8419cefbbe36a674daed13ae62f48e3c85.png)
Marijus
Vemund
4
Thanks for the swift reply!
Turned out to be an user error.
-FILTER was a Wireshark caputre file, wrongly stored on the router.
No trouble at all! We’re here to assist you. If you have any further questions, don’t hesitate to get in touch.
Marijus
system
Closed
6
