itsam
November 22, 2023, 2:04pm
1
which FQDN is needed for firmware updates on the RUTX08?
I must open the firewall in front of the RUTX08 and tried firmware.teltonika-networks.com but without success.
Edit:
See in Status → Realtime Data → Connections some tcp connections from the WAN IP to:
xxx.amazonaws.com:5000
Has this something to do with the firmware check?
For the FOTA updates on the device, please refer to the following comment:
The device uses hostname rut.teltonika.lt for checking the updates. Port 5000 is used to initiate a connection with the FOTA server and check if update for the modem or the firmware is available.
Hope this helps!
Hope this helps!
system
Closed
December 7, 2023, 2:05pm
4
