I need to be able to disconnect a specific wifi client from RUT241 routers, preferably using the CLI. What are you using for this purpose?
- Anders
Thanks for reaching us, to disconnect a specific Wi-Fi client from RUT241 routers using the command line interface (CLI), you can use the following steps:
If you’re more comfortable using the web interface, I recommend following the steps outlined in the documentation to set up the MAC filtering feature.
Thanks,
Mahmoud
Thanks And there is no way of simply disconnecting a client without blocking their MAC address (and then unblock when they are allowed to connect again)?
Will the wireless restart command force all clients to reconnect?
To block and disconnect a specific MAC address from the command line interface (CLI), you can follow these steps:
This will effectively block the MAC address ‘32:D9:09:EF:9A:3F’ from connecting to your wireless network.
If you want to remove the block and allow access again, you can use these commands:
Additionally, if you want to forcefully disconnect a client without permanently blocking its MAC address, you can use the iw command. For instance, if your wireless interface is ‘wlan0’ and the client’s MAC address is ‘12:34:56:78:90:AB’, you would run:
This command sends a deauthentication frame to the client, causing it to disconnect from the network temporarily. Please note that this method relies on the client’s behavior to reconnect once the deauthentication process is complete.
Yes, the command to restart the wireless interface.
Thanks,
Mahmoud
Thanks Mahmoud
