Hey there,
my FMC 003 with firmware 03.29.00.Rev.358 behaving a bit weird since yesterday.
Somehow it hasnt updated its location even though it moved a lot.
It still sends on Stop data every hour with a gps fix which was true 5 hours ago.
Downloaded the logs via Fota and found the line "
No fix reason: 3841
maybe someone can help me here
More logs because I can not attach a file:
U ‰qÖ‰€A
Started:2025-5-30 10:20
Uptime: 15d 16h 19min 2s
PWR rsn:SoftReset Cnt:0 Abn:0
Mode:Unknown on Stop
SpcId:1
UpdRes:-65536
U ‰q׉€ GPS Fix: 0
No fix reason: 3841
GPS state: 6
TTFF: 4s
TTLF: 0s
NoFix: 25795s
Latitude :48.615872
Longitude:13.177385
Altitude Y U -q׉€ :0
FW Ver: AXN_5.1.9
SN mode: 1
U Eq׉€ TSYNC: Last Sync:NTP at 1749957684s, NTP cnt:100, Fails:0
Ž U qŒ‰€ð[MODEM.STATUS]
6 U ‰qŒ‰€ð CCID : 8944501606231217166
IMSI : 234502106121716
Data Link : 0/0/0/0/0/0
GPRS Status : 0
Phone Status: 0
‹ U 5qŒ‰€ð PIN Attempts : 3,3
GSM Operator: 26201
C U ‰qŒ‰€ð Bat. Charge : 0
GSM Signal : 4
Service : 0
New Message : 0
Roaming : 1
SMS Full : 0
Voice Call : 0
LAC U ‰qŒ‰€ð : 21037
Cell ID : 29968129
CFUN : 1
CSQ (rssi) : 19
QCSQ (rssi) : -0 dBm
QCSQ (rsrp) : -40 dBm
QCSQ (sin ò U mqŒ‰€ðr) : -9.6 dB
QCSQ (rsrq) : -18 dB
[0]SIM detected: 1
Network Type: 2/4G
Current LTE BAND: 0
U iqŒ‰€ð Modem (Relative / Absolute):
StPin fails : 0 / 0
AT dead cnt : 0 / 0
Init fails : 0 / 0
W U uq? ‰€ð[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 0, battery prot not active
‘ U ]q? ‰€ð[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 12400 BatV: 4060 BatI: 0
U a½3‰ @ÿÿÿ Ž U eqþ7‰€ð[GPS.TEST] [GPS.DATA] gps state: OFF
status FIX: 0
No fix reason: 3841
moment RMC status: j U ‰qþ7‰€ðtude: 0.000000, good latitude: 48.615872
moment longitude: 0.000000, good longitude: 13.177385
moment altitude: 0.000000, good ª U ‰qþ7‰€ðaltitude: 0.000000
moment speed: 0.000000, good speed: 0.000000
moment angle: 0.000000, good angle: 0.000000
moment gps sats in Ð U ‰qþ7‰€ð view/use: 0/0
moment galileo sats in view/use: 0/0
moment glonass sats in view/use: 0/0
moment beidou sats in view/use: 0/0
moment total GSA sats in use: 0
status time: 00:00:00
status date: 2000.00.00
GPS init status: 0 — U
qþ7‰€ð
U uq±9‰€ð[LiPo] cant en charger; Vext: 1, Vbat: 0, first charger: 0, addon: 1, dsleep: 0, battery prot not active
U ]q±9‰€ð[LiPo] BatState: 1 FSMState: ACTIVE ChargerIC: OFF ExtV: 12402 BatV: 4060 BatI: 0
U iq†:‰€ð[2025.06.15 03:31:19]-[AXL.APP] WARNING @ 232:Unexpected count 617 (600 +/- 2 of AXL Updates
H U a†:‰
@:Uni ) U =q C‰€ð[REC.GEN] .0 Not enough records to send! Min:1/0
Ö U qq´D‰€ð[OBDII] State:IDLE(8) Lock:1 (cnt:0) Protocol:0 (last:6) Vext:12400 MovI:0 MovD:0 Header:0x7E8 Phy:0
o U ‰q´D‰€ð[OBDII] VIN:MMCXTA03AKH208498 Avail:0xBE3FA813;0x9005A001;0xFED08040;0x00000000;0x00000000;0x00000000 PidCnt:0 ICtyp:3 ICver:v1 á U !q´D‰€ð00.11800.100 CfgMode:1
P U Yq´D‰€ð[OBDII] NoECU:0 NoPID:0 0x00000000;0x00000000;0x00000000;0x00000000;0x00000000;
P U ‰q´D‰€ð[OBD.OEM] OEM Diagnostics:
OBDII data: 0
VIN VEH: MMCXTA03AKH208498 (manual:0), source: 1
Current state: 5 (Data requesting) U ‰q´D‰€ð
FSM error occured: 0
Request error occured: 0
DataInfo is present: 1
New DataInfo present: 0
Request retry timer: 0 s
Re è U 9qµD‰€ðquest retry count: 0
General error count: 0
