FMB920 + Escort TD BLE Fuel Sensor Preset Missing in Configurator 1.20.0.0
Hello Team,
I am trying to integrate an Escort TD BLE fuel sensor with a Teltonika FMB920.
Device:
  • FMB920
  • Firmware: 04.00.00 Rev.13
  • Configurator version: 1.20.0.0
Sensor:
  • Escort TD BLE
  • Bluetooth 4.0
  • MAC Address available
I followed the Teltonika documentation and set:
  • Bluetooth 4.0 enabled
  • Non Stop Scan enabled
  • BT Power Level 7
  • BLE Connection Control allowed
When I select Advanced Mode under Bluetooth 4.0 → Custom Sensors, the configurator only displays the Advanced Configuration table.
According to the documentation, I should be able to load an Escort Fuel BLE preset, but no preset selection button appears.
Could you please advise:
  1. Whether Configurator 1.20.0.0 supports Escort TD BLE presets?
  2. Which Configurator version should be used?
  3. What is the correct configuration procedure for Escort TD BLE sensors on FMB920?
Thank you.
Thanks for writing to us.
From the same window, please scroll to the right. You will find the Preset Button option, which allows you to select a predefined profile for the BLE sensor.
Simply choose the preset that matches your BLE device. If your BLE device is not available in the list, please create a support ticket and attach the BLE protocol documentation for the device.
Once we have the protocol document, we can review the data being broadcast by the BLE sensor, identify the relevant bytes and parameters, and determine whether it can be supported. If supported, we can create and save a new preset profile for that BLE device.
Hello Ashutosh,
Thank you very much for your response and for your guidance.
I followed the steps you recommended and successfully loaded the “escort fuel” preset in the Bluetooth 4.0 settings. I then uploaded the updated configuration to the FMB920 through FOTA WEB.
Unfortunately, I am still facing the same issue.
The GPS tracker is working normally, and the vehicle has already generated hundreds of AVL records after the new configuration was applied. The truck is currently operating in international transit and is moving continuously, but no BLE fuel parameters are being received in Wialon.
The following parameters are completely absent from the raw AVL data:
  • io_270
  • io_273
  • io_306
  • io_307
Device Information
  • Device: FMB920
  • Firmware: 12.0.0
  • Platform: Wialon Hosting
  • Fuel Sensor: Escort TD BLE
  • Codec: Codec 8 Extended
Configuration Verified
Bluetooth 4.0 Settings
  • Non Stop Scan: Enabled
  • BLE Connection Control: Allow
  • BT Power Level: 7
  • Working Mode: Advanced
Sensor Configuration
  • Sensor #1 configured in Advanced Mode
  • Official “escort fuel” preset loaded
  • MAC address entered manually
  • Data Clear Period: 0 seconds
I/O Settings
  • BLE LLS #1 → Low Priority
  • BLE LLS Frequency #1 → Low Priority
The MAC address is correct, as it was taken directly from a photo during installation, and the fuel sensor battery was confirmed to be in good condition.
At the moment, physical access to the vehicle is not possible because the truck is already in transit in another country.
Could you please advise on the following:
  1. Is there a way to verify remotely whether the FMB920 is actually detecting the BLE sensor?
  2. Are there any additional parameters that should be enabled?
  3. Could the Escort TD BLE be using a different advertising format that requires manual configuration instead of the default preset?
  4. Is there any remote diagnostic procedure that we can perform without accessing the vehicle physically?
Thank you very much again for your support.
Fiston Niyera
FISTEX
Burundi
  • Could the Escort TD BLE be using a different advertising format that requires manual configuration instead of the default preset? This could be the issue, so please check with the Escort team once.
  • You can also use the SMS command btgetlist 3. Once sent, the device will scan and list all nearby BLE devices but for this sms command NON stop can must be disabled first. This will help verify whether the Escort TD BLE is advertising correctly and whether the device is able to detect it.
