Your recommendation worked perfectly. After adding the two spaces before the command, I successfully received the BLE scan results, and the FMB920 was able to detect the Escort sensor:
E81CB6DFAE14,TD_921142
This confirms that the sensor is advertising and that the tracker can detect it correctly.
However, I am still not receiving any BLE fuel parameters (IO 270, IO 273, IO 306, etc.) in Wialon.
I am currently coordinating with the supplier and their technical team to verify whether this particular Escort TD BLE sensor requires any specific configuration or uses a different BLE data format.
I will provide an update once I receive their feedback.
The data is not being received because the BLE sensor must first be configured under the Advanced BLE Settings.
A preset for the Escort TD-BLE sensor is available in the preset list. Kindly select this preset and configure the priority of each required I/O element as Low, High, or Panic. If the priority remains disabled, the corresponding sensor data will not be included in the generated records.
For more information about the Advanced BLE configuration, please refer to the following Teltonika Telematics Wiki page:
