RUT 955 and 956
How to use user_pass to mobile SMS gateway earlier firmware works fine but this want now lowercase letter too
RUT 955 and 956
In older firmware versions, there were no password restrictions on the SMS POST/GET functionality. However, allowing weak passwords is not a secure practice. As a result, in the newer firmware version, an important change has been made: users are now required to use stronger, more secure passwords.
While it is still technically possible to change the password to a less secure one through the CLI/SSH, it is strongly discouraged. If there is an absolute necessity to make this change, it can be done, but it is not recommended:
#generate a new password where 'pass1' is your actual password:
openssl passwd -6 -salt abcd pass1
# Take the hash of the password from the output of the previous command and modify the password field in the configuration:
vi /etc/config/post_get
/etc/init.d/sms_utils restart
