Firmware upgrade by sms command
When sending an SMS command for a firmware update, if the Firmware on server - %fs flag is not true, the firmware update is not performed, only the modem restarts.
What is required, when receiving a firmware update command, the modem will check if there is a new version on the server, before the update process.
Please ensure that your device has internet connectivity when attempting to update the firmware from the server.
The device is connected.
The problem is, if we don’t first check on the web that there is a new version, the %fs flag is NO, then the SMS command does not update a version.
If the result of the %fs flag is YES, it will update.
