Firmware update failed
I tried to update the RUTX11 firmware. It did not work. After 15 minutes I turned off the router. After switching on again, only the power Lampe flaches. That all. I also tried resetting. No result found.
What else can I do now? Or have I destroyed something?
Mike
You can also attempt to access your router through the bootloader and update your devices firmware that way. Follow the instructions provided here to upgrade your device’s firmware: Link to instructions.
Marijus
