Firmware 7.14 concerns
RUTX50 I have my own files and programs running under /usr/xxxx and I configured updates not remove my rc.local or crontab
Will this upgrade mess everything I done ?
Read-only root filesystem for maximum reliability
rutos-714-in-article2.png|840xauto
Most notably, the root filesystem is now set to read-only by default. This change protects critical system files from unauthorised or accidental modifications, helping maintain long-term device stability.
While standard configurations remain unaffected, advanced users who require more flexibility will still be able to implement custom firmware solutions.
Yes, /usr is read-only, unless you are using /usr/local or /usr/share then you will be fine. More information can be found in Implementation of Read-Only System Files and Mobile and I/O POST/GET Service Removal with RutOS 7.14 - #4 by Marija topic.
Then I stay away from future updates until I hade time to reconfig and recode a lot of things. This warning should be huge, many times I just click update and is fine.,… Luckly I read up this time… Teltonika could ruin alot over the summer for me when all need to be stable.
What about crontab’s ?
Hello @fableman,
Crontab functionality remains the same as in previous firmware versions.
