Hi Teltonika,
I don’t have lots of experience with firewall settings but already spent many hours trying to make the setup work. Here is what i want:
- Via VPN connection with RUT241 (works, login in RUT via VPN works)
- Via VPN connect to LAN connected PLC (192.168.1.2). Does only work when I forward al ports via a trafic rule
- So I want to acces the RUT241 OR the PLC, not only one of them. So im stuck in the port forwarding.
How can I setup the port forwarding in such a way that I can acces both the RUT241 and the PLC?
