Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP all – 0.0.0.0/0 0.0.0.0/0 match-set ipb_port_dest src,dst,dst
DROP all – 0.0.0.0/0 0.0.0.0/0 match-set ipb_port src,dst
DROP all – 0.0.0.0/0 0.0.0.0/0 match-set ipb_mac src
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 /* !fw3 /
input_rule all – 0.0.0.0/0 0.0.0.0/0 / !fw3: Custom input rule chain /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED / !fw3 /
syn_flood tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:0x17/0x02 / !fw3 /
zone_lan_input all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_input all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_input all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain FORWARD (policy ACCEPT)
forwarding_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom forwarding rule chain /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3: IPsec bypass for offloading / policy match dir in pol ipsec
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3: IPsec bypass for offloading / policy match dir out pol ipsec
FLOWOFFLOAD all – 0.0.0.0/0 0.0.0.0/0 / !fw3: Traffic offloading / FLOWOFFLOAD hw
zone_lan_forward all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_forward all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_forward all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain OUTPUT (policy ACCEPT)
output_rule all – 0.0.0.0/0 0.0.0.0/0 / !fw3: Custom output rule chain /
zone_lan_output all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_output all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
zone_wan_output all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain forwarding_lan_rule (1 references)
Chain forwarding_rule (1 references)
Chain forwarding_wan_rule (1 references)
Chain input_lan_rule (1 references)
Chain input_rule (1 references)
Chain input_wan_rule (1 references)
Chain output_lan_rule (1 references)
Chain output_rule (1 references)
Chain output_wan_rule (1 references)
Chain reject (0 references)
REJECT tcp – 0.0.0.0/0 0.0.0.0/0 /* !fw3 / reject-with tcp-reset
REJECT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */ reject-with icmp-port-unreachable
Chain syn_flood (1 references)
RETURN all – 0.0.0.0/0 0.0.0.0/0 limit: avg 25/sec burst 50 /* !fw3 /
DROP all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain zone_lan_dest_ACCEPT (4 references)
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 /* !fw3 */
Chain zone_lan_forward (1 references)
forwarding_lan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom lan forwarding rule chain /
zone_wan_dest_ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3: Zone lan to wan forwarding policy /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate DNAT / !fw3: Accept port forwards /
zone_lan_dest_ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain zone_lan_input (1 references)
input_lan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom lan input rule chain /
ACCEPT udp – 0.0.0.0/0 224.0.0.251 udp spt:5353 dpt:5353 / !fw3: Allow-mDNS /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate DNAT / !fw3: Accept port redirections /
zone_lan_src_ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain zone_lan_output (1 references)
output_lan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom lan output rule chain /
Chain zone_lan_src_ACCEPT (1 references)
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate NEW,UNTRACKED /* !fw3 */
Chain zone_wan_dest_ACCEPT (3 references)
DROP all – 0.0.0.0/0 0.0.0.0/0 ctstate INVALID /* !fw3: Prevent NAT leakage /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 /
DROP all – 0.0.0.0/0 0.0.0.0/0 ctstate INVALID / !fw3: Prevent NAT leakage /
Chain zone_wan_forward (2 references)
forwarding_wan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom wan forwarding rule chain /
zone_lan_dest_ACCEPT esp – 0.0.0.0/0 0.0.0.0/0 / !fw3: Allow-IPSec-ESP /
zone_lan_dest_ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:500 / !fw3: Allow-ISAKMP /
zone_wan_dest_ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain zone_wan_input (2 references)
input_wan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom wan input rule chain /
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:68 / !fw3: Allow-DHCP-Renew /
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 8 / !fw3: Allow-Ping /
ACCEPT 2 – 0.0.0.0/0 0.0.0.0/0 / !fw3: Allow-IGMP /
zone_wan_src_ACCEPT all – 0.0.0.0/0 0.0.0.0/0 / !fw3 */
Chain zone_wan_output (2 references)
output_wan_rule all – 0.0.0.0/0 0.0.0.0/0 /* !fw3: Custom wan output rule chain /
Chain zone_wan_src_ACCEPT (1 references)
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate NEW,UNTRACKED /* !fw3 /
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate NEW,UNTRACKED / !fw3 */
