I followed the instructions for M-bus. I’m testing with the FCB toggle “on”, it reads some of the data, you see in the picture.
When FCB toggle is “off” , it reads all the data but, when I test again, it does not read the data. I change the FCB toggle “on” position again, it reads all the data. When I save and try again, it does not read data again, I think this cycle will continue forever. What could be the reason?
What brand meter are you using? I cant read the text in the images?
I have the same problem with a Garo (rebranded Carlo Gavazzi).
It seems that after the first reply from the meter (replies with 3 frames) all subsequent responses are the values from the third frame which are values of negative transfer (eg solar production or simiar). These values will always be 0 in a normal installation.
Is it possible to cat the live response in terminal?
According to the manual one should program it with the first request (VIF/VIFE values) but I cannot get this to work either,
I sent 4 e-mails to Gavazzi and they didn’t respond. Teltonika said, we will check. I ordered an energy analyzer 7KT1667 from Siemens. I will try it, if again same problem then I will change Teltonika.
