I have a RUT956 and have managed to lock myself out of it. I was trying to set it up to use WiFi for communication and to use it to send data to Azure as iot hub.
How do I reset it so I can access it again. Once reset how do I configure it so I can use WiFi for connection as the Iot hub. I do not want to use the mob sim option as where it is proposed to be used it has poor 4g/5g service but a good WiFi network access.
Could you clarify what steps you took to set up the Wi-Fi?
Also, are you trying to access the device via Wi-Fi or with an Ethernet cable?
If you’re unable to access the device’s WebUI, you could try a factory reset.
For connecting to the router via Wi-Fi, I’ll provide instructions below on how to do it:
You can simply disable the mobile interface if you don’t want to use it, or avoid inserting a SIM card into the device
If you will have any further questions, please let us know.
Z
