Problem as in the topic.
RUT955, FW: RUT9_R_00.07.02
It is not possible to change the software. Uploading (sysupgrade -F) ends with restoring factory settings.
I found some information on the firmware page for the RUT955: RUT955 Firmware Downloads - Teltonika Networks Wiki, where it states:
There is the possibility that the RUT9_R_00.07.02 firmware that you are trying to use is not supported on your device and legacy FW needs to be used instead. https://wiki.teltonika-networks.com/images/e/ef/RUT9XX_R_00.06.09.5_WEBUI.bin
We can verify if your router is one of the RUT955 7V models, but we need a troubleshooting file to do so.
To generate Troubleshoot file: RUT955 Maintenance - Teltonika Networks Wiki (teltonika-networks.com)
I have sent you instructions on how to send this troubleshooting file to us via Hubspot.
