EYE-SENSOR configuration via api
Hello, just wanting to find out if there is a way to configure the EYE-SENSOR via api from the teltonika after pairing. I know, for the device to send temp, humidity etc.. i need to configure the protocol for sensor data instead of eddystone but I have to do this via the App which makes it next to impossible to configure it remotely without asking someone to download the app and doing the configuration.
So I was wondering, is it possible to, after sshing in, manually send commands via api to the sensor after it has paired to my teltonika (rutx series in this case). I would imagine the app is doing exactly this?
Good afternoon,
Remote full configuration of the EYE sensor protocol via API on the Teltonika device is not supported; you will need to use the EYE APP for sensor configuration and then use the Teltonika device API or UI to manage data collection and forwarding.
If remote configuration without app installation is critical, consider scripting Bluetooth commands externally.
Arturas
