In a RUTX09 or in general on all models with Input, can I apply an external voltage of 12Volt coming from a source other than the power supply to the PIN input (IN THIS CASE PIN4)? (sharing mass obviously)
I just need to understand if I’m getting voltage from a system and I simply wanted to put a small power source that comes from that line to monitor the status of the power supply (present or absent)
I hope I explained myself.
Thanks for the support
You can indeed apply voltage to a specific pin. Just be cautious not to exceed 30 volts, as this could harm the device.
For further information on the power options and input/output details for the RUTX09, you can visit these links:
- Powering Options: RUTX09 Powering Options - Teltonika Networks Wiki
- Input/Output Details: RUTX09 Input/Output - Teltonika Networks Wiki
Marijus
Grazie ! ![]()
