Extend my network
Hello and many thanks in advance for your help.
Here is y problem.
I have two Teltonika routers.
A RUTX10 and a RUTX08 in two different area.
They are linked together by a wired connection.
2 PC are connected to the RUTX10 and 3 to the RUTX08.
How can i configure the routers so that all the PC are on the same network ?
PS : i know i should have brough a teltonika switch instead of the RUTX08 as in fact i want the RUTX08 to act almost as a switch but now it’s too late ;(…
Many thank in advance.
You just need to change IP one of RUTX and disable DHCP server and do WAN as LAN on RUTX08.
I.e.:
RUTX10 192.168.1.1, DHCP on
RUTX08 192.168.1.2, DHCP off
RUTX08 WAN as LAN in “basic configuration mode” under “Network->LAN”
after this all devices connected to LAN ports will be in the same network. Routers should be connected RUTX10 in LAN, RUTX08 in WAN.
Many thanks ! It worked !
Regards
