I am facing an issue with a router RUT956. The Root Partition of the device is entered in read-only mode. I think the cause of this problem is that the disk space in use is 96%. Indeed, when I log in into the device through SSH, the device returns this message: “Your JFFS2-partition seems full and overlayfs is mounted read-only. Please try to remove files from /overlay/upper/… and reboot!”
However, every time I try to run the command “rm” on some files, the system replies with “can’t remove […]: Read-only file system”. Moreover, I cannot unmount the root partition while the device is running and the fsck utility is not installed on the device (so I cannot check the integrity of the disk).
How can I solve this situation?
Federico
