Hi, the CLI command not work:
root@Teltonika-RUT955:/log# /etc/init.d/eventslogs restart
-ash: /etc/init.d/eventslogs: not found
What can I do?
What can I do?
Thank you for your inquiry. Please note that you should use the following command instead:
/etc/init.d/log restart
Additionally, could you confirm which RutOS firmware version your RUT955 is running on?
Device: RUT955
Kernel: 5.4.259
Firmware: RUT9_R_00.07.06.17
Build: a4aefd8a170
Build date: 2025-01-06 07:09:12
