I am interested to implement Teltonika router in EV bus in order to enable monitoring different paramaters related to the battery (temperature, SoC, generate alarms etc…).
The bus logger device is communicating through CAN-BUS, the goal is to convert the CAN-BUS and publish the data through cloud services to some server.
What’s the suggested way working with Teltonika when the edge device is CAN-BUS like in this case ?
Teltonika Networks devices do not support the CAN protocol. Special hardware is required, and a significant amount of software work is needed to enable this functionality.
