Is it possible to read the Ethernet/IP protocol of an Allen Bradley PLC values with the Teltonika modem and convert the data as Json format and upload it with the “Data to sender” for us on our server.
With OPC_UA it works but unfortunately Allen Bradley does not support OPC_UA
Yes, it is possible to read PLC register data using Modbus TCP Client on the router and then send those values in JSON format through the Data to Server service via HTTP or MQTT protocols.
For more detailed information and configuration steps, you may find the following wiki topics useful:
