eSIM Provider for RUT241
I just tried to test my recently purchased RUT241 eSiM router.
I tried to load a 2 day Europe eSIM from HolyFly, but I only get a Fatal Error with no further details while downloading the eSim data (Activation code and QR code).
Is there anybody who successfully could use any eSIM profile ?
My use case is to have it on a sailing boat, crossing multiple countries, mainly EU, and enable us to havbe Internet during our trips.
The RUT241 has current firmware.
Chris
I have sent you a form to fill out. Once completed, I will contact you privately regarding this issue.
Please use “12529” as the ticket ID.
The issue was that the device didn’t have an active internet connection.
Just a quick reminder—to install an eSIM profile, the device must have an active WAN connection. This can be:
  • Wired WAN (connected via Ethernet cable to the router’s WAN port)
  • WiFi WAN (e.g., using a hotspot from your phone)
I have a similar issue in Austalia with Holafly, I can get the eSim profile loaded but it will not register to the carrier. all i get is the following:
2499 Thu Mar 6 09:32:48 2025 daemon.info gsmd[1585]: Modem 1-1 [2c7c:0125] URC Event: ESM reject cause => Unknown ESM reject cause
2500 Thu Mar 6 09:33:33 2025 daemon.info gsmd[1585]: Modem 1-1 [2c7c:0125] URC Event: ESM reject cause => Unknown ESM reject cause
2501 Thu Mar 6 09:34:50 2025 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “300s” of timeout
2502 Thu Mar 6 09:35:20 2025 daemon.info gsmd[1585]: Modem 1-1 [2c7c:0125] URC Event: ESM reject cause => Unknown ESM reject cause
Actually, got it working. I enabled roaming on the eSIM as Holify uses multuiple carriers. Also had to install the APN database package to create a custom APN.
Hello @dasemm,
I’m glad to hear that you found a solution!
If there’s anything else I can assist you with regarding this topic, please let me know.
Hello, I have somehow the same problem. I upload in the esim profile the qr code and I get the message that the profile is downloading. After a few seconds, I get the message that the esim profile failed to be downloaded. I mention that my computer is connected to internet via wifi and the router is connected to my computer via lan
Hello @danciolan,
Could you please confirm if your router has internet access? It can be connected to another device via an Ethernet cable into the WAN port, or you can connect your router to a WiFi network, just as you connected your PC.
Yes, the router was connected to internet via wan port.
For the ticket ID, please use “12529”.
Our developers are actively working on resolving this issue, and the fix is planned to be implemented in the RutOS 7.14 firmware version.
Unfortunately, I don’t have an exact release date yet, but I will update you here as soon as I have any news.
Thank you for your patience and understanding.
Hello @chris9927 @dasemm @danciolan,
The latest 7.14 firmware has been released and is available for download here:
Could you please test it and let me know if it resolves the issue?
This topic was automatically closed after 12 days. New replies are no longer allowed.
