Error firmware RUT2_R_00.07.06.6 and RUT2_R_00.07.06.8 with IPSEC
Please fix a ticket
After updating more than 15 RUT240 to firmware RUT2X_R_00.07.06.6, the where no IPSEC-Connections to my sophos firewall.
After updating the firmware to **RUT2_R_00.07.06.8, it still doesn’t work.
Installing this firmware version via RMS is a problem. Furthermore, the RMS does not always show the .08 version as installed.
I need some help to fix it
thx
Maik
I too can’t get an IPSEC VPN to work using this firmware.
I have made the IPsec server configuration according to the RUT240 example ( Setting up an IPsec tunnel between RUT and Android phone - Teltonika Networks Wiki ).
Firmware RUT2_R_00.07.06.8, the update was successful via the LAN port.
The server starts.
When you are connected to the RUT240 wifi network with an android mobile device, you can connect to the IPsec server. Connecting via the mobile network is not possible (daemon.info ipsec: 06[IKE] <MyIPsec-MyIPsec_c|25> unable to resolve %any, initiate aborted)
Is there a solution or tip for this problem?
