Equivalent to RUT-955 of a few years ago with 1Gbit Ethernet?
I was wondering if you cold help me. We are currently using some old models RUT-955 (id is RUT95517V180) and we would like to upgrade them to the newer version of the router. I had a look at the RUT-956 but its Ethernet Ports speed is 10/100 and we need 10/100/1000 like the Ethernet Ports on our current old RUT-955.
I see that there are several routers that have the 10/100/1000 speed for the ethernet ports but I am unsure which would be the best like for like replacement for the old RUT-955.
Any suggestion or recommendations?
Many thanks
Mike
Greetings, @mikec
Thank you for reaching out.
We offer a wide range of devices that support 10/100/1000 Mbps Ethernet speeds. To recommend the most suitable option, could you please describe your current use case and the key features you require in a replacement router?
As an alternative to the RUT955, I would recommend the RUTX11, which supports 10/100/1000 Mbps Ethernet speeds. The RUTX11 also features a more advanced Wi-Fi setup, offering dual-band Wi-Fi 5 (2.4 GHz and 5 GHz) for improved performance, higher data throughput, Bluetooth support for IoT sensors, beacons, short-range integrations, faster LTE (LTE Cat 6 up to ~300 Mbps), eSIM profile support (depending on model), more advanced networking features (load balancing, DNS over HTTPS, VRF).
I also suggest taking a look at our full product lineup on the website, where you can filter devices based on Ethernet speed and other required features: Teltonika Ethernet and 4G/5G Cellular Routers
If you are currently using the RS232 or RS485 serial ports on your RUT955 for industrial machinery, please let me know so I can provide a more tailored recommendation. Some serial functionality can also be achieved on the RUTX11 via its USB port.
Povilas
Thanks for your reply Povilas.
We are having issues migrating from a RUT-955 to RUT-956 and we thought that it might be due to the Ethernet port speed but we are less convinced of that now. We have found a spare TRB-500 (which it has a 10/100/1000 port ) and will test with that on site.
Will update the post with the result of the test.
Thanks again
Mike
