good morning community,
I am running a RUTX09 LTE router for some time now which has no build in wifi card.
Is there a possibility to enhance the router with a USB-Stick in order to provide also an Wifi-AP for internet connection? If so, do you have recommondations / experiences which WiFi USB Stick will work easily with this setup?
Bernd
Thank you for your inquiry.
Unfortunately, no, the RUTX09 router does not support adding a wireless access point (AP) using a USB Wi-Fi stick. The device lacks built-in Wi-Fi drivers and configuration interfaces necessary to handle external USB Wi-Fi adapters directly.
If you need Wi-Fi functionality, a recommended solution is to connect a dedicated Wi-Fi router or access point to one of the RUTX09’s Ethernet LAN ports. This will allow you to provide Wi-Fi access while maintaining the RUTX09 as your main LTE router.
Should you need further assistance, feel free to reach out.
