Hello out there,
I am using RUT955 in a RV-vehicle. On board cabin power is by 12V LiFePo4 battery system and RUT955 is permanently connected to cabin power. Cabin power and engine starter battery (12V lead acid) are linked by a Votronic vcc 1212-50 is a b2b charger without (!) galvanic isolation. The Votronic is a high end device: Votronic 3326 vcc 1212-50 12v to 12v 50a b2b charging converter
On some occasions, RUT does stop recording GPS data to the inserted memory card, but also sporadically resumes recording. Here is the relevant portion of recorded data. I am using the latest firmware, of course.
$GPRMC,150007.00,A,4759.283201,N,00747.925420,E,0.0,80.0,120124,0.5,W,A,V*6E
$GPGGA,150010.00,4759.283162,N,00747.925566,E,1,08,0.6,237.8,M,48.0,M,*69
$GPGGA,0,66
$GPRMC,V,N53
$GPGGA,0,66
$GPRMC,V,N53
$GPGGA,134838.00,4855.089867,N,00809.927714,E,1,08,0.6,111.4,M,48.0,M,65
$GPRMC,134838.00,A,4855.089867,N,00809.927714,E,0.0,0.0,130124,0.5,W,A,V53
I observe that RUT955 stopped recording after engine shutdown followed by an engine re-restart (diesel engine).
GPS recording eventually resumed after a further engine stop and restart the next day (no other system intervention during this time). There was another engine stop-start sequence during the GPS drop-out however, which did not trigger the GPS to resume recording.
Note that the RUT955 is permanently connected to cabin power and usually also records GPS data even while engine is not running. Most of the time GPS recording is not affected by engine stops and starts. The drop-out only occurs once in a while.
My suspicion is that some sort of Electromagnetic Compatibility issue with the power system may trigger GPS recording to fail but also to resume again.
Question 1: has anybody ever experienced the same problem on a vehicle mounted system ?
Question 2: could the problem be caused by some sort of Electromagnetic Compatibility issue (EMC) ?
Question 3: could some sort of noise filter in the power supply help ? which kind of filter could be used ?
Any suggestion welcome !
Regards, Mike.
