i run mailserver on local machine. then i run telnet commands from cli on rut 906, email server awnser and replay awnser. then use email to sms it will not work, router run firmware rut9m_r_00.07.11.3
have also test to make configuration in cli it will get same result as using web configuration email to sms.
Could you please replicate the issue and then navigate to System → Maintenance → Troubleshoot? Once there, press Show next to System.log to check for any logs related to this issue.
Have also update firmware to RUT9M_R_00.07.12, but i get same result.
according to log in mailserver tektonika get awnser but never send user and password to mailserver. see log form mailserver " “TCPIP” 8836 “2025-01-25 10:27:58.809” “TCP - 192.168.45.1 connected to 192.168.45.90:110.”
“POP3D” 8836 842 “2025-01-25 10:27:58.814” “192.168.45.1” “SENT: +OK POP3” "
mailserver have ip adress 192.168.45.90 and teltonika have ip adress 192.168.45.1
Could you please let me know which port you are using for the server port? Additionally, could you share which other ports you have tried and whether the issue persists with all of them?
using port 465 with startttls works on rut 906, on rut956 i get same error as i get on 906 before i change to port 465, have used same setings in rut956 as i have in rut 906. running firmware RUT9M_R_00.07.12 on rut 956
