Easier way to configure multiple Teltonika's with a similar config?
We currently use RUT956 (RUT955 in the past) and always import backups to configure them. Lately we’ve been experiencing more and more issues with this method (incorrect firmware, difference in product number, …) making this a bit more tedious and difficult to configure in bulk.
Is there a way you can configure everything in CLI or create a CLI script to configure them?The differences between configuration for the different devices are minor (different name, IP, IPSEC identifier, …), all other values remain the same. I’ll also add that we use 3 profiles per device.
Anyone have any experience configure Teltonika’s this way?
Tom
We recommend using the RMS platform to configure multiple devices simultaneously. You can find more information on how to do this here: How to Configure Devices from RMS.
Please let me know if you have any further questions or require assistance with this.
Hi Marija,
We already use RMS, but it is not feasible for this particular case. That’s why I wanted to see if CLI was an option, besides importing backups everytime.
Tom
Teltonika routers have documented API (https://developers.teltonika-networks.com/).
There is also CLI helper for it. For e.g to change lan interface ip - api put /interfaces/config/lan "{'data': {'ipaddr': '192.168.1.20'}}"
