Dual modem rutm52 - network testing each modem - balancing accordingly?
I found this to be a fairly good solution - binding iperf in client mode to the moderm interface:
iperf3 --bind-dev qmimux0 -c remotefastserver.org
iperf3 --bind-dev qmimux1 -c remotefastserver.org
it would be beautiful to build a feedback of the results into the multiwan config.
Thank you for the feedback. I’ll create a suggestion for our R&D team.
The R&D has responded to the request, saying the following -
The biggest issue is that periodic speed tests will consume very high amounts of data, and, at least as of now, we don’t have our own servers for that. It would also be unfair and unreliable to use third-party servers for this purpose. My suggestion would be to use a custom user script in the client’s responsibility to measure and change the Mwan priority accordingly.
