Drop-In Mode like Pepwave
Hello.. New to Teltonika devices.. Looking for advice for replacing a Pepwave MAX BR1 Mini that is operating in what they call Drop-In mode. The wan port is on a private IP and is bridged to the LAN using the same subnet. When the wan port is failed, it auto fails over to the mobile link.
Is this the same as passthrough??
Rob
What you’re referring to is probably the Failover functionality, which can be found here: RUT951 Failover - Teltonika Networks Wiki
This example is specifically for the RUT951, but it applies to all of our devices.
As for bridging, our devices also support that functionality; a few examples with bridge-related configurations can be found here:
