I’m starting to look into the RMS api, however it’s not clear to me if I could use this to control a relay on the TRB141 for example? If yes, then what would this look like?
Certainly, you can control relays or execute any command remotely using SSH. The RMS platform provides a “task manager” feature that allows you to execute commands compatible with the router’s SSH functionality.
An example command to control a relay looks like this:
ubus call ioman.relay.relay0 invert_state '{"save_conf": true}'
For detailed documentation on the RMS API, you can refer to: RMS API Documentation
This documentation will guide you on using POST/GET requests and executing commands. Additionally, there are examples of requests related to tasks and their groups.
Feel free to explore the documentation for more information.
Marijus
