Does my RUT955 supports E-sims
Dear Teltonika Users,
I am playing around with my RUT955 in combination with a physical E-sim which a have to install with my dongle and put it in the physical slot of the RUT955. On the wiki I saw that the RUT955 can support e-sim. After upgrading the Firmware the E-sim functionality is not visible.
On the Datasheet I see that it is a (optional?). Is there a way to get it working or should I buy another device like the RUT241?
Thanks for helping
Routers with eSIM support: Teltonika Ethernet and 4G/5G Cellular Routers
Doesn’t seem that RUT955 supports eSIM out of box, so it’s probably needs custom order for it to support.
Hello @jlenoir,
As lemondude mentioned, the RUT955 can support eSIM only if a new product code is created, since eSIM requires different hardware.
Could you please let me know if there is anything else I can assist you with?
How can RUT955 support eSIM when the product has already reached end of life?
I was confused because the following information is available on the DATASHEET
SIM 2 x SIM slots (Mini SIM - 2FF), 1.8 V/3 V, external SIM holders, eSIM (Optional).
I now also learned that the RUT955XXX code is the indication of you have the esim version or another one. This was perhaps also the reason I could find examples on the WIKI for the E-SIM support on the RUT955. Never the less I got this one for free and will replace it with a newer version.
Thanks for helping
Hello @hrtx,
Apologies for any confusion. When the RUT955 was still in production, customers could order a custom product code for a version that included eSIM. Now, this is no longer possible because the RUT955 is an EOL (End-of-Life) device as you have mentioned. The information about the RUT955 eSIM only applies to users who previously ordered the device with a custom product code.
If you need a device with eSIM that is still in production, you can either:
1. Contact us via our official website to request a custom product code, or
2. Choose a device that already includes eSIM without creating a custom code.
Hope this clarifies the situation.
