Does any obvious reason exist why the 12 / 15 V (USB-C PD) PEPLINK ACW-791 wouldn't be able to power the 9 to 50 V RUTXR1?
Context
All of Teltonika’s official MOLEX Micro-Fit PSUs contain undetachable cables, meaning that I’m forced to utilise an unbraided Micro-Fit cable, and a BS 1363 (IEC 60083 Type-G) socket.
This isn’t ideal for my conditions, because although I’ve a lot of spare USB-C PD sockets (Micro-Fit is DC), I’ve not many spare Type-G sockets.
Problem
Consequently, I asked Stack Exchange for a recommendation:
I received one that appeared perfect, in the PEPLINK ACW-791. (Two USB-C PD inputs to one MOLEX Micro-Fit output). However, at least when connected to a SATECHI ST-C200GM-UK, my RUTXR1 didn’t boot.
PEPLINK Support states that it should provide this:
The Micro-Fit connector will output the same voltage (either 12V or 15V) that it receives from the USB-C power source. It does not alter or regulate the voltage in between those values.
  • If the USB-C power source provides 12V, the Micro-Fit will output 12V.
  • If the USB-C power source provides 15V, the Micro-Fit will output 15V.
There is no capability to output a voltage between 12V and 15V; the output will match the input voltage exactly.
After informing them that this combination doesn’t work, they’ve directed me to ask Teltonika, because they don’t see a reason why the specifications would be incompatible, for the RUXR1 supports 9 to 50 V PSUs.
Location
Asking this Discourse instance appears more sensible than asking Teltonika directly, considering that I presume that a non-official PSU isn’t directly supported.
Thank you for your observations and for sharing your findings regarding your setup. I’ve forwarded all the necessary details to our electronics R&D team to clarify this behavior.
Once we receive any updates or feedback from them, I’ll make sure to inform you here accordingly.
Thank you for your patience and understanding.
Hello @RokeJulianLockhart,
After some further digging, it seems that the ACW-791 Molex Micro-Fit pinout differs from Teltonika’s 4-pin Molex PSU connector. On the ACW-791, the GND and V+ are located, let’s say, on pins 3 and 4, whereas our official PSUs use a different pin assignment. My guess is that this mismatch is the reason why your RUTXR1 does not boot when powered through the ACW-791.
For reference, here’s a related discussion on the Peplink forum that might be useful:
@anon65719490, thank you, sincerely! What excellent customer service. For anyone coming from Google, I’ve transferred the discussion to that Discourse instance instead:
