Hi Teltonika Support Team,
I’m running a RUTX50 router on a sailing vessel and planning to deploy Signal K (a marine data aggregation server) as a Docker container on the device.
Before proceeding, I’d like to confirm: does the RUTX50 support Docker in the current RutOS firmware? I noticed the wiki page for “RUTX50 Docker” exists but contains no content, so I’m unable to determine if this is a supported feature.
Specifically, I need to know:
1. Is Docker available via the Package Manager on RUTX50?
2. If yes, which minimum RutOS firmware version is required?
3. Are there any known limitations (storage, RAM) I should be aware of?
The use case is lightweight — Signal K as a data bridge between NMEA 2000 sensors and a cloud server, with no heavy processing on the router itself.
Thank you.
Robert Šarić
