Hello Martynas,
Thank you for your reply.
Here is my configuration.
Cisco Side
Crypto Config:
crypto ikev2 proposal VPN_PROPOSAL
encryption aes-cbc-256
integrity sha256
group 19
crypto ikev2 policy VPN_POLICY
crypto ikev2 profile TELTONIKA_PROFILE
match certificate TELTONIKA_CERT_MAP
identity local fqdn hub.LOTR.co.uk
authentication remote rsa-sig
authentication local rsa-sig
pki trustpoint starwars-CA
crypto ikev2 nat keepalive 10
crypto ipsec transform-set VPN_TRANSFORM_SET esp-aes 256 esp-sha256-hmac
mode transport
crypto ipsec profile TELTONIKA_IPSEC_PROFILE
set transform-set VPN_TRANSFORM_SET
set pfs group19
set ikev2-profile TELTONIKA_PROFILE
Interface Config:
interface Tunnel601
description TELTONIKA_DMVPN
ip address 192.168.10.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication hobbit
ip nhrp network-id 5
ip nhrp holdtime 300
no ip nhrp shortcut
ip nhrp redirect
ip tcp adjust-mss 1360
bfd interval 1000 min_rx 1000 multiplier 5
tunnel source GigabitEthernet0/0/0.500
tunnel mode gre multipoint
tunnel key 6500
tunnel protection ipsec profile TELTONIKA_IPSEC_PROFILE
Router BGP
router bgp 64600
bgp router-id 192.168.10.1
bgp log-neighbor-changes
bgp redistribute-internal
network 10.10.10.0 mask 255.255.255.0
redistribute connected metric 20 route-map CONN2BGP
redistribute static metric 20 route-map STATIC2BGP
neighbor 10.10.10.15 remote-as 64600
neighbor 10.10.10.15 next-hop-self
neighbor 192.168.10.101 remote-as 64600
neighbor 192.168.10.101 next-hop-self
neighbor 192.168.10.102 remote-as 64600
neighbor 192.168.10.102 next-hop-self
neighbor 192.168.10.103 remote-as 64600
neighbor 192.168.10.103 next-hop-self
neighbor 192.168.10.104 remote-as 64600
neighbor 192.168.10.104 next-hop-self
Teltonika Side
DMVPN PARAMETERS CONFIGURATION
Enable – on
Working mode – spoke
Hub address – PUBLIC-IP
GRE PARAMETERS CONFIGURATION
Tunnel source – set to MOB1S1A1
Local GRE interface IP address – 192.168.10.102
Remote GRE interface IP address – set to 192.168.10.1
GRE MTU – set to 1400
Outbound key – 6500
Inbound key – 6500
IPSEC PARAMETERS CONFIGURATION
Leave local and remote identifier fields empty
Pres-shared key – THIS IS WHERE I CAN’T SELECT BETWEEN PRE-SHARED KEY and X509A Authentication
IPSEC PROPOSAL CONFIGURATION
PHASE 1 Encryption algorithm – set to AES 256
Authentication – set to SHA256
DH group – set to ECP256
Force crypto proposal – leave set to off
IKE lifetime – set to 8h
PHASE 2 Encryption algorithm – set to AES 256
Hash algorithm – set to SHA256
PFS group – set to ECP256
Lifetime – set to 8h
NHRP PARAMETERS CONFIGURATION
NHRP network ID – set to 5
NHRP authentication key - hobbit
NHRP hold time – set to 300
Redirect – leave set to off
