Disconnects with OpenVPN to RMS
My VPN connection to RMS keeps disconnecting. Sometimes between 2 to 3 times within a minute. I have tested this on 2 different networks but the issue stays the same. Below you can find OpenVPN log.
⏎[Nov 22, 2023, 15:19:21] Client terminated, restarting in 2000 ms…
⏎[Nov 22, 2023, 15:19:21] SetupClient: signaling tun destroy event
⏎[Nov 22, 2023, 15:19:22] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:19:22] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:19:22] Contacting 3.65.167.143:38700 via UDP
⏎[Nov 22, 2023, 15:19:22] EVENT: WAIT ⏎[Nov 22, 2023, 15:19:22] WinCommandAgent: transmitting bypass route to 3.65.167.143
“host” : “3.65.167.143”,
“ipv6” : false
⏎[Nov 22, 2023, 15:19:23] Connecting to [3.65.167.143]:38700 (3.65.167.143) via UDPv4
⏎[Nov 22, 2023, 15:19:32] Server poll timeout, trying next remote entry…
⏎[Nov 22, 2023, 15:19:32] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:19:32] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:19:32] Contacting 3.69.106.81:38700 via UDP
⏎[Nov 22, 2023, 15:19:32] EVENT: WAIT ⏎[Nov 22, 2023, 15:19:32] WinCommandAgent: transmitting bypass route to 3.69.106.81
“host” : “3.69.106.81”,
“ipv6” : false
⏎[Nov 22, 2023, 15:19:33] Connecting to [3.69.106.81]:38700 (3.69.106.81) via UDPv4
⏎[Nov 22, 2023, 15:19:42] Server poll timeout, trying next remote entry…
⏎[Nov 22, 2023, 15:19:42] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:19:42] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:19:42] Contacting 3.65.167.143:38700 via UDP
⏎[Nov 22, 2023, 15:19:42] EVENT: WAIT ⏎[Nov 22, 2023, 15:19:42] WinCommandAgent: transmitting bypass route to 3.65.167.143
“ipv6” : false
⏎[Nov 22, 2023, 15:19:43] Connecting to [3.65.167.143]:38700 (3.65.167.143) via UDPv4
⏎[Nov 22, 2023, 15:19:43] EVENT: CONNECTING ⏎[Nov 22, 2023, 15:19:43] Tunnel Options:V4,dev-type tun,link-mtu 1541,tun-mtu 1500,proto UDPv4,keydir 1,cipher BF-CBC,auth SHA1,keysize 128,tls-auth,key-method 2,tls-client
⏎[Nov 22, 2023, 15:19:43] Creds: UsernameEmpty/PasswordEmpty
⏎[Nov 22, 2023, 15:19:43] Peer Info:
IV_VER=3.git::d3f8b18b
IV_PLAT=win
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305:BF-CBC
IV_AUTO_SESS=1
IV_GUI_VER=OCWindows_3.3.6-2752
IV_SSO=webauth,openurl,crtext
IV_BS64DL=1
⏎[Nov 22, 2023, 15:19:43] SSL Handshake: peer certificate: CN=teltonika-vpn-pMcNEUfYxTmxtfNe, 2048 bit RSA, cipher: TLS_AES_256_GCM_SHA384 TLSv1.3 Kx=any Au=any Enc=AESGCM(256) Mac=AEAD
⏎[Nov 22, 2023, 15:19:43] Session is ACTIVE
⏎[Nov 22, 2023, 15:19:43] EVENT: GET_CONFIG ⏎[Nov 22, 2023, 15:19:43] Sending PUSH_REQUEST to server…
⏎[Nov 22, 2023, 15:19:43] OPTIONS:
0 [comp-lzo] [no]
1 [route] [10.100.2.0] [255.255.255.0]
2 [route] [10.100.3.0] [255.255.255.0]
3 [route] [10.100.1.0] [255.255.255.0]
4 [route] [192.168.255.0] [255.255.255.0]
5 [topology] [net30]
6 [ping] [5]
7 [ping-restart] [15]
8 [ifconfig] [192.168.255.6] [192.168.255.5]
9 [peer-id] [2]
10 [cipher] [AES-256-GCM]
⏎[Nov 22, 2023, 15:19:43] PROTOCOL OPTIONS:
cipher: AES-256-GCM
digest: NONE
key-derivation: OpenVPN PRF
compress: LZO_STUB
peer ID: 2
control channel: tls-auth enabled
⏎[Nov 22, 2023, 15:19:43] EVENT: ASSIGN_IP ⏎[Nov 22, 2023, 15:19:43] CAPTURED OPTIONS:
Session Name: 3.69.106.81
Layer: OSI_LAYER_3
Remote Address: 3.65.167.143
Tunnel Addresses:
192.168.255.6/30 → 192.168.255.5 [net30]
Reroute Gateway: IPv4=0 IPv6=0 flags=[ IPv4 ]
Block IPv6: no
Add Routes:
10.100.2.0/24
10.100.3.0/24
10.100.1.0/24
192.168.255.0/24
Exclude Routes:
DNS Servers:
Search Domains:
⏎[Nov 22, 2023, 15:19:44] SetupClient: transmitting tun setup list to \.\pipe\agent_ovpnconnect
“allow_local_dns_resolvers” : false,
“confirm_event” : “ec15000000000000”,
“destroy_event” : “3015000000000000”,
“tun” :
“adapter_domain_suffix” : “”,
“add_routes” :
“address” : “10.100.2.0”,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“prefix_length” : 24
“address” : “10.100.3.0”,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“address” : “10.100.1.0”,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“address” : “192.168.255.0”,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“block_ipv6” : false,
“layer” : 3,
“mtu” : 0,
“remote_address” :
“address” : “3.65.167.143”,
“ipv6” : false
“reroute_gw” :
“flags” : 256,
“ipv4” : false,
“ipv6” : false
“route_metric_default” : -1,
“session_name” : “3.69.106.81”,
“tunnel_address_index_ipv4” : 0,
“tunnel_address_index_ipv6” : -1,
“tunnel_addresses” :
“address” : “192.168.255.6”,
“gateway” : “192.168.255.5”,
“ipv6” : false,
“metric” : -1,
“net30” : true,
“prefix_length” : 30
“wintun” : false
POST np://[\.\pipe\agent_ovpnconnect]/tun-setup : 200 OK
TAP ADAPTERS:
guid=‘{002521F3-069E-4F29-B8A5-910F5E55810C}’ index=2 name=‘LAN-verbinding 2’
Open TAP device “LAN-verbinding 2” PATH=“\.\Global{002521F3-069E-4F29-B8A5-910F5E55810C}.tap” SUCCEEDED
TAP-Windows Driver Version 9.24
ActionDeleteAllRoutesOnInterface iface_index=2
netsh interface ip set interface 2 metric=1
Ok.
netsh interface ip set address 2 static 192.168.255.6 255.255.255.252 gateway=192.168.255.5 store=active
IPHelper: add route 10.100.2.0/24 2 192.168.255.5 metric=-1
IPHelper: add route 10.100.3.0/24 2 192.168.255.5 metric=-1
IPHelper: add route 10.100.1.0/24 2 192.168.255.5 metric=-1
IPHelper: add route 192.168.255.0/24 2 192.168.255.5 metric=-1
ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
TAP: ARP flush succeeded
TAP handle: 1c07000000000000
⏎[Nov 22, 2023, 15:19:44] Connected via TUN_WIN
⏎[Nov 22, 2023, 15:19:44] LZO-ASYM init swap=0 asym=1
⏎[Nov 22, 2023, 15:19:44] Comp-stub init swap=0
⏎[Nov 22, 2023, 15:19:44] EVENT: CONNECTED 3.65.167.143:38700 (3.65.167.143) via /UDPv4 on TUN_WIN/192.168.255.6/ gw=[192.168.255.5/]⏎[Nov 22, 2023, 15:20:28] Session invalidated: KEEPALIVE_TIMEOUT
⏎[Nov 22, 2023, 15:20:28] Client terminated, restarting in 2000 ms…
⏎[Nov 22, 2023, 15:20:28] SetupClient: signaling tun destroy event
⏎[Nov 22, 2023, 15:20:30] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:20:30] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:20:30] Contacting 3.65.167.143:38700 via UDP
⏎[Nov 22, 2023, 15:20:30] EVENT: WAIT ⏎[Nov 22, 2023, 15:20:30] WinCommandAgent: transmitting bypass route to 3.65.167.143
“ipv6” : false
⏎[Nov 22, 2023, 15:20:30] Connecting to [3.65.167.143]:38700 (3.65.167.143) via UDPv4
⏎[Nov 22, 2023, 15:20:32] EVENT: CONNECTING ⏎[Nov 22, 2023, 15:21:30] EVENT: PAUSE ⏎[Nov 22, 2023, 15:21:30] EVENT: RESUME ⏎[Nov 22, 2023, 15:21:30] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:21:30] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:21:30] Contacting 3.69.106.81:38700 via UDP
⏎[Nov 22, 2023, 15:21:30] EVENT: WAIT ⏎[Nov 22, 2023, 15:21:30] WinCommandAgent: transmitting bypass route to 3.69.106.81
“ipv6” : false
⏎[Nov 22, 2023, 15:21:30] Connecting to [3.69.106.81]:38700 (3.69.106.81) via UDPv4
⏎[Nov 22, 2023, 15:21:40] Server poll timeout, trying next remote entry…
⏎[Nov 22, 2023, 15:21:40] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:21:40] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:21:40] Contacting 3.65.167.143:38700 via UDP
⏎[Nov 22, 2023, 15:21:40] EVENT: WAIT ⏎[Nov 22, 2023, 15:21:40] WinCommandAgent: transmitting bypass route to 3.65.167.143
“ipv6” : false
⏎[Nov 22, 2023, 15:21:40] Connecting to [3.65.167.143]:38700 (3.65.167.143) via UDPv4
⏎[Nov 22, 2023, 15:21:50] Server poll timeout, trying next remote entry…
⏎[Nov 22, 2023, 15:21:50] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:21:50] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:21:50] Contacting 3.69.106.81:38700 via UDP
⏎[Nov 22, 2023, 15:21:50] EVENT: WAIT ⏎[Nov 22, 2023, 15:21:50] WinCommandAgent: transmitting bypass route to 3.69.106.81
“ipv6” : false
⏎[Nov 22, 2023, 15:21:50] Connecting to [3.69.106.81]:38700 (3.69.106.81) via UDPv4
⏎[Nov 22, 2023, 15:22:00] Server poll timeout, trying next remote entry…
⏎[Nov 22, 2023, 15:22:00] EVENT: RECONNECTING ⏎[Nov 22, 2023, 15:22:00] EVENT: RESOLVE ⏎[Nov 22, 2023, 15:22:00] Contacting 3.65.167.143:38700 via UDP
⏎[Nov 22, 2023, 15:22:00] EVENT: WAIT ⏎[Nov 22, 2023, 15:22:00] WinCommandAgent: transmitting bypass route to 3.65.167.143
“ipv6” : false
⏎[Nov 22, 2023, 15:22:00] Connecting to [3.65.167.143]:38700 (3.65.167.143) via UDPv4
⏎[Nov 22, 2023, 15:22:04] EVENT: CONNECTING ⏎[Nov 22, 2023, 15:22:04] Tunnel Options:V4,dev-type tun,link-mtu 1541,tun-mtu 1500,proto UDPv4,keydir 1,cipher BF-CBC,auth SHA1,keysize 128,tls-auth,key-method 2,tls-client
⏎[Nov 22, 2023, 15:22:04] Creds: UsernameEmpty/PasswordEmpty
⏎[Nov 22, 2023, 15:22:04] Peer Info:
IV_PLAT=win
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_AUTO_SESS=1
IV_BS64DL=1
⏎[Nov 22, 2023, 15:22:04] SSL Handshake: peer certificate: CN=teltonika-vpn-pMcNEUfYxTmxtfNe, 2048 bit RSA, cipher: TLS_AES_256_GCM_SHA384 TLSv1.3 Kx=any Au=any Enc=AESGCM(256) Mac=AEAD
⏎[Nov 22, 2023, 15:22:04] Session is ACTIVE
⏎[Nov 22, 2023, 15:22:04] EVENT: GET_CONFIG ⏎[Nov 22, 2023, 15:22:04] Sending PUSH_REQUEST to server…
⏎[Nov 22, 2023, 15:22:04] OPTIONS:
0 [comp-lzo] [no]
6 [ping] [5]
9 [peer-id] [0]
⏎[Nov 22, 2023, 15:22:04] PROTOCOL OPTIONS:
cipher: AES-256-GCM
digest: NONE
compress: LZO_STUB
peer ID: 0
⏎[Nov 22, 2023, 15:22:04] EVENT: ASSIGN_IP ⏎[Nov 22, 2023, 15:22:04] CAPTURED OPTIONS:
Layer: OSI_LAYER_3
Tunnel Addresses:
Block IPv6: no
Add Routes:
10.100.2.0/24
10.100.3.0/24
10.100.1.0/24
192.168.255.0/24
Exclude Routes:
DNS Servers:
Search Domains:
⏎[Nov 22, 2023, 15:22:05] SetupClient: transmitting tun setup list to \.\pipe\agent_ovpnconnect
“confirm_event” : “fc15000000000000”,
“destroy_event” : “3c12000000000000”,
“tun” :
“add_routes” :
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“gateway” : “”,
“ipv6” : false,
“metric” : -1,
“net30” : false,
“layer” : 3,
“mtu” : 0,
“remote_address” :
“ipv6” : false
“reroute_gw” :
“flags” : 256,
“ipv4” : false,
“ipv6” : false
“ipv6” : false,
“metric” : -1,
“net30” : true,
“wintun” : false
TAP ADAPTERS:
Ok.
ipconfig /flushdns
TAP handle: 2c18000000000000
⏎[Nov 22, 2023, 15:22:05] Connected via TUN_WIN
⏎[Nov 22, 2023, 15:22:05] LZO-ASYM init swap=0 asym=1
⏎[Nov 22, 2023, 15:22:05] Comp-stub init swap=0
⏎[Nov 22, 2023, 15:22:05] EVENT: CONNECTED 3.65.167.143:38700 (3.65.167.143) via /UDPv4 on TUN_WIN/192.168.255.6/ gw=[192.168.255.5/]⏎
Thank you for reaching out!
Could you clarify if this behavior was tested on multiple machines with OpenVPN client?
Perhaps the same .ovpn file is used for multiple OpenVPN client instances? This could cause a similar behavior, as the file should only ever be used by one user. Another user can be added to the VPN hub if multiple client connections are needed.
Finally, could you try configuring VPN Hub in a different region? Sometimes latency issues could result in a similar behavior.
No we dont use this openvpn file simultanously with a another client. I think you have an issue with your germany dc. I have created 2 new hubs. One with germany as a location and one with Bahrain. The one with germany is unstable and the one with Bahrain is stable. I myself am located in the Netherlands.
