Disabling NAT for WireGuard on Teltonika Devices
I am using a Teltonika router with WireGuard VPN, and I would like to configure it so that connected clients use their real IP addresses without NAT. Currently, when a device is connected to WireGuard (e.g., with IP 172.16.51.4), its traffic appears to originate from 172.16.51.1 due to NAT.
Could you please provide guidance on how to disable NAT for WireGuard, allowing clients to retain their original IP addresses while communicating over the VPN?
I appreciate your assistance and look forward to your response.
In the UI go to Network->Firewall->zones, disable masquerading for wireguard=>lan.
Hello @arbek,
Could you please confirm if your topic has been resolved, or do you still need any assistance with this?
The issue has been resolved, thank you.
Thank you for confirming!
