DIN rail adapter for RUT 241
I bought the metal DIN rail adapter kit: DIN rail kit
And I have RUT241.
There are no screws included.
RUT241 does not seem to have any holes. How are the DIN rail kits supposed to be fitted onto RUT241?
There are tracks on the back and both sides of the 240/241 that are supposedly used to screw into but this particular DIN rail kit doesn’t meet my expectations either. What I use for the 240/241 is PR5MEC22 and adapt this to/using a DIN rail clip like this one DIN Rail Mounting Clips, Plastic - Winford Engineering
End up with a non metallic/non rusting mount from which the unit can be very easily detached/replaced.
Thank you. Weirdly, my DIN rail kit didn’t include screws. I even got a photo from retailer which showed that they should’ve been attached to a piece of paper - no way I would have lost that. In any case, turns out you can use something like 6-32 UNC computer screws, so I just reused some of them.
Hmm, didn’t realise it can rust. Thank you for pointing that out, I’ll need to keep an eye on it! Although I would have imagined it would have made from zinc alloy which would be rust resistant just as much as the DIN rail itself.
I don’t use any thing other than alloy DIN rail and non metallic (as such) clips. I like the PR5MEC22 for the 241’s, RUTX50 I custom make myself, 955 & 956’s have inbuilt screw mounts which can be retro fitted to acceptable DIN rail fittings.
