Different SSID on router
I have a fresh out the box router which has a SSID printed on the case. the SSID on the case says: RUT240_765C (and has a password printed).
However, when I power the router is only see SSID: RUT240_26F3, and I cannot access it with the printed WiFi password. I have tried resetting the router, but the SSID remains the same.
Feels like a provisioning issue, how can I resolve this and get access to the router?
Could you please confirm whether you are able to access the WebUI
(QSG – RUT240 WebUI Access Guide) using the password printed on the back panel of the router? Or is that password also being reported as incorrect?
I can access the WebUI, but the password is also reported as incorrect.
If I understand correctly, you are unable to log in to the WebUI because the password on the device’s back panel is incorrect, even after a factory reset. Is that right?
Additionally, please try to access the Bootloader menu and update the device firmware through it, as described here: RUT240 Device Recovery Options - Teltonika Networks Wiki
If, even after using the bootloader menu, both the WebUI password and the SSID continue to show as incorrect, please contact your distributor for an RMA.
