DHCP with two LAN interfaces not working
Using a RUT241 to have internet to several desktop PCs via WIFI and also to access a local test subnet.
The regular LAN interface is set at 192.168.55.1/24 with DHCP enabled.
Another LAN interface is added at 192.168.10.1/24 with no DHCP, bridged to the lan/wifi interface.
I have setup routers like this before, this meant that all PCs could get a 55.x ip from the dhcp, whereas all devices that connected with a static 10.x ip could be accessible from the 55.x network.
Now using the RUT241 with latest firmware RUT2M_R_00.07.08, no devices receive DHCP, even though in the DHCP menu only the 55.x DHCP server is enabled, and the 10.x is disabled.
How can I avoid this? The moment I delete the second LAN, everything starts working as usual, just without access to 10.x.
