I am trying to connect a Raspberry Pi to the network wit PiHole installed so I can use this as my DNS server.
I should add that this is my first Teltonika Router so I’m still learning!
The router is a RUTX-50 and has the latest firmware (modem too)
The Raspberry Pi is a Pi Zero 2-W which will only work on the 2.4Ghz frequency and is a headless device.
I connected the Pi to my laptop via Ethernet, pinged it by hostname to get the IP, SSH in to edit the wpa supplicant config and gave it the details of a 2.4GHZ test network I created on the RUTX-50
I can see it connect and disconnect from the Teltonika interface (Status/Network) but it isn’t recognising the hostname and it isn’t assigning an IP address.
The top line in the image below is my laptop, the second line is the Raspberry Pi.
I have tested this further but always with the same result.
However, one thing I have noticed is that the Teltonika interface continues to show the Raspberry Pi as a connected wireless client even after I power it (the Pi) off.
The only way I’ve found to clear it from the list is to reboot the RUTX-50.
If I try connecting the Pi via ethernet to the RUTX-50 then it recognises the hostname and assigns a DHCP lease so it seems it’s an issue with the WiFi interface somehow.
Today I added some new Wireless interfaces on the RUTX-50 and doing this somehow seems to have corrupted the connection to the Pi (which is connecting on a different pre-existing interface).
It lost both hostname and IP address until I rebooted.
The MAC address of the Pi is used to assign a static lease and on rebooting both devices I was able to re-establish this, but the hostname is no longer recognised.
While I can work around it, it does sound like a bug in the Teltonika software as the Pi was working perfectly and has not been changed since then.
